USB with Docker on Windows and macOS Now Possible: What You Need to Know
Hardware developers have missed out on the benefits of Docker and similar localized container solutions for one big reason: USB. Today we’re seeing how devices can start to reliably connect from the host system to the container.
I have a career-long passion (borderline obsession) with developer tools. I want them to be great and search for ways to make them better for every developer. All steps in the program / test / debug loop require access to devices via USB. For some time, Docker has supported USB device access via --device on Linux, but left Windows and macOS users in a lurch. As of Docker Desktop 4.35.0, it is now possible to access USB devices on Windows and macOS as well! It’s early days and caveats abound, but we can genuinely say Docker is starting to finally become a useful tool for hardware developers.
Why USB in Docker Matters
Working with USB devices inside containers adds a bit of complexity compared to native tools. They add a variable in the process and are yet another tool to manage. But there’s value in using containers for development: namely reproducibility and environment isolation. It’s also worth noting that USB device access isn’t only relevant to hardware devs; anyone using a USB-based peripheral like a midi controller also know the struggle.
On Linux, Docker can take advantage of native OS features to allow containerized processes to directly interact with USB devices. However, on Windows and macOS, Docker runs within a virtual machine (VM), meaning it doesn’t have direct access to the host’s hardware in the same way Linux does.
USB Limitations for macOS and Windows Users
For years, Windows and macOS users have faced a clunky workaround:
  • Running Docker inside a Linux VM
  • Passing USB devices through to that VM
  • Passing them into Docker containers.
While this approach works, it is resource-intensive, slow, and far from seamless. Many developers voiced frustration over this in GitHub issues, such as this long-running thread that discusses the challenges and demands for native USB passthrough support.
In reality, most hardware developers don’t end up leveraging Docker for local development because of the lack of USB access, only relegating containers to CI/CD and test automation.
A Solution: USB/IP
USB/IP is an open-source protocol that is part of the Linux kernel that allows USB devices to be shared over a network. By using a USB/IP server on the host system, USB devices can be exposed to clients (such as remote servers or containers) over the network. The client, running inside a Docker container, can access and interact with the device as though it were directly connected to the container.
usbip-design
Via https://usbip.sourceforge.net/
In theory, enabling USB/IP for Docker would allow USB devices to be accessed from within containers, bypassing the need for complex VM setups. This would simplify the experience, offering access to USB devices without the overhead of virtualization.
Making It Happen: Collaborating with Docker
While USB/IP provided the perfect solution for Docker’s USB problem, Docker hadn’t yet implemented USB/IP as part of its official features.
In February of this year, I reached out to the Docker team to see if it would be possible to integrate USB/IP into Docker Desktop. I got connected to Piotr Stankiewicz, a senior software engineer at Docker, to discuss the possibility of adding support for USB/IP. Piotr was immediately interested, and after a few discussions, we began collaborating on requirements.
Finally, after several months of work by Piotr and testing by me, Docker Desktop 4.35.0 was released, featuring support for USB/IP.
Key Concepts Before We Begin
Before diving into the steps for enabling USB device access, it’s important to understand the basic configuration. The key idea is that USB devices are passed through from the host system into a shared context within Docker. This means that every container on your machine could theoretically access the USB device. While this is great for development, be cautious on untrusted machines, as it could expose your USB devices to potentially malicious containers.
Setting Up a Persistent Device Manager Container
One of the best ways to manage this is by setting up a lightweight “device manager” container, which I’ll refer to as devmgr. This container will act as a persistent context for accessing USB devices, so you don’t have to repeat the setup every time you want to develop code in a new container. By keeping devmgr running, you can ensure that the USB device is always available to other containers as needed.
I’ve created a simple image (source) and pushed it to Docker Hub for convenience, though you can use your own image as a device manager.
Serving up USB
Next we need to figure out how to expose USB devices from the host machine, aka “the server” in USB/IP terms. Windows already has a mature USB/IP server you may have not known about; it’s called usbipd-win and is what enables USB access on WSL (which I previously wrote about.) Unfortunately, macOS doesn’t have a complete server but I was able to use this Python library to program a development board (I also tried this Rust library but it’s missing support for USB to serial devices). Developing a USB/IP server for macOS is certainly one area the community can contribute!
With the pre-reqs out of the way, we can get going.
Getting Started with Windows
1. Install prerequisites
Make sure you install Docker, usbipd-win and any device drivers your USB devices might need.
2. Select a USB device to share
Open an admin Powershell and list out the available USB devices. Note the Bus ID as we’ll use that to identify the device next.
usbipd list
3. Share a USB device via USB/IP
Binding a device to the USB/IP server makes it available to Docker and other clients. You can confirm the device is shared by calling list again.
usbipd bind -b <BUSID>
Here’s an example of the output from my machine:
PS C:\Users\jberi> usbipd list
Connected:
BUSID   VID:PID   DEVICE                                                      STATE
2-1     10c4:ee60 CP2102 USB to UART Bridge Controller                        Not shared
2-3     06cb:00bd Synpatics UWP WBDI                                          Not shared
2-4     13d3:5406 Integrated Camera, Integrated IR Camera, Camera DFU Device  Not shared
2-10    8087:0032 Intel(R) Wireless Bluetooth(R)                              Not shared
Persisted:
GUID                                DEVICE
PS C:\Users\jberi> usbipd bind -b 2-1
Connected:
2-1     10c4:ee60 CP2102 USB to UART Bridge Controller                        Shared
Persisted:
GUID                                DEVICE
4. Create a container to centrally manage devices
Start a devmgr container with the appropriate flags (--privileged --pid=host are key.)
docker run --rm -it --privileged --pid=host jonathanberi/devmgr
5. See which devices are available to Docker
In the devmgr container, we can list all the devices that the USB/IP client can grab (USB/IP calls it attaching.) One important note – we need to use host.docker.internal as the remote address to make Docker magic happen.
usbip list -r host.docker.internal
6. Attach a device to Docker
Now we want to attach the device shared from the host. Make sure to use the <BUSID> from the previous step.
usbip attach -r host.docker.internal -b <BUSID>
7. Verify that the device was attached
USB/IP can confirm the operation but since you now have a real-but-virtual device, ls /dev/tty* or lsusb should also work. You’ll need the /dev name for the next step anyway.
usbip port
Here’s another example of the output from my machine:
b6b86f127561:/# usbip list -r host.docker.internal
usbip: error: failed to open /usr/share/hwdata//usb.ids
Exportable USB devices
 - host.docker.internal
        2-1: unknown vendor : unknown prodcut (239a:0029)
           : USB\VID_239A&PID_))29\4445FEEF71F2274A
           : unknown class / unknown subclass / unknown protocol (ef/02/01)
           :  0 - unknown class / unknown subclass / unknown protocol (02/02/00)
           :  1 - unknown class / unknown subclass / unknown protocol (0a/00/00)
           :  2 - unknown class / unknown subclass / unknown protocol (08/06/50)
b6b86f127561:/# usbip attach -r host.docker.internal -b 2-1
b6b86f127561:/# usbip port
Imported USB devices
Port 00: <Port in Use> at Full Speed(12Mbps)
       1-1 -> usbip://host.docker.internal:3240/2-1
           -> remote bus/dev 002/001
b6b86f127561:/# lsusb
Bus 001 Device 001: ID 1d6b:0002
Bus 001 Device 009: ID 239a:0029
Bus 002 Device 001: ID 1d6b:0003
b6b86f127561:/# ls /dev/ttyA*
/dev/ttyACM0
8. Use your newly-attached USB device
The moment of truth! We can finally use our USB device in a development container. From the Docker perspective it is a real USB device so you can use it to flash, debug, and twiddle bits. You can, of course, use it for non-development things like hooking up a MIDI* controller – but hardware is more fun, right?
There’s unlimited configurations here so I’ll just give an example of how I’d flash a Zephyr application using an image from github.com/embeddedcontainers. Note we’re passing the /dev with --device like we would on a Linux host.
docker run --rm -it -v ${PWD}:/workdir --device "/dev/ttyACM0" ghcr.io/embeddedcontainers/zephyr:arm-0.17.0SDK
Watching west flash work for the first time felt like ✨magic✨.
* One caveat with USB/IP is that Docker may need to enable device drivers for your particular hardware. Many popular USB to Serial chips are already enabled. File an issue on github.com/docker/for-win to request additional drivers or for any other related issues.
Getting Started with macOS
The steps for macOS are nearly identical to Windows except we need to use a different USB/IP server. I’ll use one that I know works with a CP2102. It’s still flaky and only partially implemented, so we need the community to pitch in!
git clone https://github.com/tumayt/pyusbip
cd pyusbip
python3 -m venv .venv
source .venv/bin/activate
pip install libusb1
python pyusbip
Watch as we flash and monitor an ESP32 running Zephyr in Docker!
As before, Docker may need to enable device drivers for your hardware, so file any issue at github.com/docker/for-mac.
Limitations to the USB/IP approach
Obviously the glaring issue here is the UX. The manual setup is clunky and each time a device reboots, it may need to be re-attached–auto attach works pretty well in usbipd-win, though! Also, we need a proper USB/IP server implementation for macOS. Lastly, device support may be limited based on driver availability.
However, I’m optimistic that these challenges can be overcome and that we will see solutions in short time (Open Source, ftw 💪.)
The ability to access USB devices within Docker on both Windows and macOS is a big leap forward for developers, hardware enthusiasts, and anyone working with USB peripherals. While there are still some setup hurdles and device limitations to overcome, this feature has the potential to streamline development and testing processes.
Give it a try and see how it works for you. Just keep in mind that it’s still early days for this feature, so you may run into some bumps along the way. Share your feedback on our forum, and let’s help improve the developer experience of hardware developers everywhere!
Jonathan Beri is the founder and CEO of Golioth, an IoT SaaS platform making it easier for embedded devices to connect to the internet and do all the things that large scale computing enables. He can be found most nights and weekends tinkering with containers and dev boards.
Jonathan Beri
Jonathan Berihttps://golioth.io
Jonathan Beri is the founder and CEO of Golioth, a straightforward commercial IoT development platform built for scale. Jonathan has spent more than a decade building IoT solutions at companies like Google, Nest, Particle & WeWork. If you really want to get him going, ask him how he would build a real holodeck.
Notable Replies
  1. Avatar for TonyB TonyB says:
    Great article.
    While I doubt most would agree with my hardware choice, which is fine; I bought the least expensive M4 Mac Mini to run as a cheap low energy server.
    I plan to run Home Assistant and Frigate in docker. However, Frigate does not recommend doing object detection on the CPU. It seems to be common for users to use a Google Coral TPU or an Nvidia GPU. On my current linux server I have an Nvidia gpu. Though ideally on my M4 Mac Mini I would use a Google Coral TPU. The ability to access this USB device from the host machine into docker seems to be the first limiting factor.
  2. Thanks! I don’t have experience with the Google Coral TPU but I think this would be possible. If it’s a USB device it should Just Work :tm: with USB/IP. However, I’m not sure if there are any performance hits using this route (which could be tested!)
    I believe a TPU is a different kind of device from the perspective of Docker. Jeff Geerling has done a bunch of testing that might be helpful: Testing the Coral TPU Accelerator (M.2 or PCIe) in Docker | Jeff Geerling
Participants
Avatar for TonyB Avatar for jonathanberi
Comments are closed.
WiFi HaLoW with Morse Micro, Zephyr, and Golioth
Wi-Fi HaLoW enables high throughput, at a long distance using ISM band radios (850-950 MHz, depending on location). This post introduces the concepts behind the demo and shows how to use Morse Micro, Zephyr, and Golioth to send data through walls and up to the cloud.
