Digikey webinar with Golioth on June 13th 2024
Golioth will be joining our friends at Digikey on June 13th to talk about “Leveraging Zephyr to enable super-flexible IoT designs”.
Digikey is where we source many of the parts for our custom hardware and where we often order development boards for putting together demos. If you’ve seen our “Follow Along Hardware”, the product SKUs revolve around Digikey stock.
So we thought it would be a great opportunity to showcase just how many different boards, chips, and sensors we can control using the same base Zephyr code, while sending fleet back to the Golioth cloud.
What we will cover
In the upcoming webinar, we’ll cover:
  • The basics of Zephyr RTOS and how to get started designing quickly
  • How one code base can serve designs from 3 different microcontroller vendors with 3 different types of connectivity and two different sensor vendors!
    • NXP, Espressif, Nordic processors
    • Ethernet, Wi-Fi, Cellular Communications
    • Sensors from Infineon and Bosch
  • How to utilize Cloud services to deliver interesting features to a product with a single SDK install
  • How Golioth’s end-to-end Reference Designs can jumpstart your own IoT designs
  • How the recently announced Pipelines feature will enable even more flexibility in designs
How to register
Register for the event using this link. You will also be able to get access to the recording if you can’t make the live event, though Golioth staff be available for live Q&A directly after our presentation.
